BLOBEYE 05 STI WIDE TRACK BREAKING CRYSTAL GREY (DCCD 6 SPEED/BREMBOS/PPP PACKAGE)
Old 11 September 2013, 09:20 AM
Default BLOBEYE 05 STI WIDE TRACK BREAKING CRYSTAL GREY (DCCD 6 SPEED/BREMBOS/PPP PACKAGE)
ok we have another nice 70k 05 plate blobeye wide track sti in crystal grey for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
all parts are based on collection delivery can be aranged at extra cost please ask
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code
male ended later style front drive shafts excellent con £180pair
r180 larger rear drive shafts excellent working order £180pair
6 speed starter motor £45
sti larger tmic in v good con complete with genuine sti pipe work mounting brackets and larger under tray if needed great for classics and newage wrx models £150 or £180 with matching under tray
standard recirc valve excellent working order £25
550cc pink injectors excellent working order £120set
full wide track dccd sti car wiring loom uncut or modded minus small engine loom £150
standard ppp 305bhp ecu set with full key set and barrel and sendor unit for complete swap £120
prodrive ppp welbro 255 lph fuel pump excellent working order £30
coil packs excellent working order £80set
standard air box complete £20
2 port boost solenoid £20
header tank good con no leaks £25
3 pin alternator excellent working order £35
battery claim with securing bars £10
air con pump excellent working order £15
top rad hose good con £10
bottom rad hose good con £5
air con rad good con no leaks or damage £20
washer bottle with pumps £15
intake snorkel £15
alternator cover £10
WHEELS/BRAKES/SUSPENTION
114pcd wide track sti suspention set up very good con and complete £150 set
wide track later style front subframe good con £60
wide track later style rear subframe good con £60
wide track alloy front arms excellent con complete with bushes ect £80pair
wide track alloy rear trailing arms good con £80set
wide track later style steering rack steering rack £60
pas steering pump in perfect working order £70
pas pipe with remote bottle and cooler £30
EXTERIOR BODY WORK
sti front grill with badges excellent con £60
blobeye tail lights good con great hawkeye and bugeye upgrade £100pair
sti twisted side skirts in v good con great wrx upgrade £100pair
05 plate onwards sti boot lid good con with badges £60
fuel filler door £15
front window good con £45
INTERIOR
wide track later style sti door cards complete with switches etc odd mark if anything at all £100set
sti blue carpet good con no rips etc great wrx upgrade £70
sti 6 speed red stitch gearknob £25
[IMG][/IMG]
dccd buttons £15 each
newage dash top good con £30
revised material type sun visors £20pair
File Type: jpg
Old 11 September 2013, 07:24 PM
techdw
techdw's Avatar
How much for the Sti Steering wheel and spring? Any Pics?
Edit: Ignore the above just seen in the text above.
Old 11 September 2013, 09:12 PM
No probs pm me if needed
All pm's replied
Old 12 September 2013, 06:54 PM
pictures now added and all pm's replied
Old 14 September 2013, 09:56 AM
list updated all sold items removed and pm's replied
Old 15 September 2013, 01:19 PM
scoobysteve
scoobysteve's Avatar
matty any chance of the trim that goes around the drivers inside door handle, broke mine yesterday removing doorcard for new speaker install.
Old 16 September 2013, 07:27 AM
K3ogh_sti
K3ogh_sti's Avatar
What sort of condition is the front bumper in along with winglets? Cheers
Old 16 September 2013, 07:35 AM
Sorry Steve the inner handle surround goes with the door cards I'm afraid mate sorry
Old 16 September 2013, 07:37 AM
K3 sorry the bumper has already sold sorry
All pm's replied
Old 16 September 2013, 09:56 AM
listed updated all sold items removed and pm's replied
Old 16 September 2013, 03:47 PM
techno_brat
techno_brat's Avatar
depending on how my idle control valve cleaning goes tonight I might be taking one off of you
Old 16 September 2013, 04:18 PM
No problem at all we have excellent ones in stock pm me if needed then cheers
All pm's replied
Old 16 September 2013, 05:30 PM
simmo56498
simmo56498's Avatar
Hi,
Would you be interested in selling the bonnet scoop separate?, I have been trying to find one for ages.
Thanks.
Old 16 September 2013, 06:33 PM
No sorry we don't split them sorry
Old 16 September 2013, 06:54 PM
scoobysteve
no worries thanks anayway buddy
Old 18 September 2013, 08:31 AM
No problem Steve cheers
All pm's replied
Old 18 September 2013, 02:38 PM
ditchyboy
ditchyboy's Avatar
The bit around the head unit with heater controls in,can that be put in an 53 Sti without the rest of the centre console as I don't want the DCCD controls etc.just the bit for head unit and heater controls,also how hard is it to replace the heater controls over so they work properly?
How olds the clutch and are you selling separately from gearbox?
Old 18 September 2013, 05:16 PM
Sorry no its completely different you won't able fit it without the rest of the parts sorry
Old 18 September 2013, 05:54 PM
Classic_Marc
Classic_Marc's Avatar
Hi, do you have the complete exhaust system still? If so, would it fit my03 sti.
Old 18 September 2013, 06:01 PM
We do yes and yes straight fit for your year..pm me if needed
Old 22 September 2013, 06:01 PM
List updated all sold items removed and pm's replied
Old 29 September 2013, 09:09 AM
ATWRX
ATWRX's Avatar
I'll probably take the inlet manifold, how much posted?
Have the headlights gone?
Old 29 September 2013, 11:56 AM
Head lights £250 postage £12 manifold tho we have sold out sorry pm me if needed
All pm's replied
Old 29 September 2013, 03:33 PM
K3ogh_sti
K3ogh_sti's Avatar
Will you split the mirrors? I need the left one? Thanks chris
Old 29 September 2013, 03:39 PM
Il have to check what we have in stock as we sold a few of these recently il pm you when I check in the morning cheers
All pm's replied
Old 30 September 2013, 08:43 PM
grumpy567
grumpy567's Avatar
I see from one of your other adverts you were selling a black carpet for £100, I have an rb320 and im looking to change the blue original carpet for a black one. Will you take £50 and my old blue carpet for a black one, as long as it's in reasonable nick.
Old 30 September 2013, 09:24 PM
Sorry I'm afraid it's already sold sorry
All pm's replied
Old 03 October 2013, 09:50 AM
list updated all sold items listed and pm's replied
Old 10 October 2013, 04:30 PM
all pm's replied
Old 13 October 2013, 06:20 PM
nick1973
nick1973's Avatar
Just realised that I've sent you a message about the rear wing via eBay without putting two and two together, now the penny has dropped and I've realised it's the same person......doh!
Anyway, which ever message you get first, any chance the wing is still available?
Quick Reply: BLOBEYE 05 STI WIDE TRACK BREAKING CRYSTAL GREY (DCCD 6 SPEED/BREMBOS/PPP PACKAGE)
