Styling Exterior styling
Blobeye Gril Refresh Ideas (Picture Heavy)
Old 07 October 2013, 09:56 PM
Rob Day
Rob Day's Avatar
Default Blobeye Gril Refresh Ideas (Picture Heavy)
Well after plenty advice, but unfortunately no pictures I decided to create my own basic thread on upgrading your Blobeye grill.
Firstly remove the ******, there are a series of clips on the top, and two at the bottom that need a long screwdriver to reach.
No pics of this being removed, but to be honest this is child play.
This image is one of google search as I forgot to take one of my own car
As you can see mine has faded quite a bit on the right hand side.
Now it's out as one unit, unclip the 7 metal clips using either pliers or a flat screw driver, and unclip the mesh grill from the top
It might seem harsh, but it worked for, cut out the centre emblem and frame, I did this slowly to ensure I didnt scratch the fascia keeping well away from the main fascia. Dont forget to rest the unit one something soft so not to scratch it whilst you do it.
The upper side was easier to cut, and to be honest this will be more hidden once installed.
Harsh but fair.
The bottom part is one you need to be more careful with, but to be honest take your time and ensure you dont accidentally gouge the facia to save prep later. I used nibblers raher than a saw, but in hindsight it might have been easier with the saw.
Dremel and sanding down required.
Flatted out the chopped out area and roughed up the whole panel.
Washed down
Filler required.
Roughly done, but my first effort
Sanded down, quite please, but feeling **** about it being right
Washed down, and filler again, and sanded again.
Cleaned thorough with soap and water to remove all grime and grease
Several primer coats.
Slight ridge bugging me to hell
More filling LOL
Now happy after fine sanding down
Satin black coat number 1
3 coats later.
Painted the metal clips in the meantime, as they looked shat
Install grill, using newly painted clips, try hooking the top on first as its a pest in the corners if you don't.
Very pleased with the result
Yes I lost one clip, I will look tomorrow as it's gone dark out ;(
Oh and I laquered the whole thing too with three coats, as its clear that these can be subject to stone chips.
Test fit.
Old 07 October 2013, 09:58 PM
tubbytommy
BANNED
tubbytommy's Avatar
now do the sti badge black
good right up rob, good to see it went well
Old 07 October 2013, 10:11 PM
Rob Day
Rob Day's Avatar
Yeah I wasn't sure whether to leave it, as it kind of breaks it up, plus I've still got the ghey pink fog stickers
Old 07 October 2013, 10:14 PM
tubbytommy
BANNED
tubbytommy's Avatar
a bit of heat and they come off easy enough.
Old 08 October 2013, 06:47 AM
scotty boy 80
scotty boy 80's Avatar
Looks good mate crackin write up for anyone too
Old 08 October 2013, 08:08 AM
Fleetster
Fleetster's Avatar
Great write up!, ive been looking at other grills but this has got me thinking now...
Old 08 October 2013, 08:38 AM
scotty boy 80
If anyones thinking of doing this and has the grille with the blue subaru badge, I have the pink badge grille and would like to swap for the blue one
Old 08 October 2013, 09:48 AM
Rob Day
Rob Day's Avatar
Cheers, its a bit of a rough write up, but its idiot proof, I mean it must be, I did it
Do it, its simple, just a little time needed. To cut and prep, 1 hour max, and that with taking pictures and being **** about it. this took me around 2 hours actual work with filler drying time, and around 6 hours with paint coats allowing 1 hour between coats.
Just buy a replacement Oval bud, and whilst it out paint the ****** , as your likely looking at P&P costs otherwise for both grills which out weighs the point you can replace the oval http://dsa.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
Rob
Old 08 October 2013, 12:51 PM
JamesDundee
JamesDundee's Avatar
Brilliant!
Old 08 October 2013, 03:48 PM
jamie_sti
jamie_sti's Avatar
looks good mate
Old 10 October 2013, 07:35 PM
Rob Day
Rob Day's Avatar
Originally Posted by JamesDundee
Brilliant!
Originally Posted by jamie_sti
looks good mate
Cheers. Picture don't do it justice nor does the test fit as I've yet to complete the Blobeye light upgrade. Plus I'm putting some hella sirens behind the grill.
I'm around half way with the look I want at the front of the car.
Rob
Old 10 October 2013, 07:42 PM
LeeRoyV
LeeRoyV's Avatar
Great right up pal looks ace
Old 11 October 2013, 08:10 AM
domino46
domino46's Avatar
Looking good , I did the same to the front of my hawkeye
Old 21 October 2013, 09:01 PM
martin850
martin850's Avatar
Nice job.
Old 22 October 2013, 08:19 PM
G4rfo
G4rfo's Avatar
good job m8
Old 04 November 2013, 08:21 PM
Rob Day
Rob Day's Avatar
One I've just done over the weekend for a chap on here. If anyone else wants there's doing, please drop me a pm
Rob
Before
Serious amount of chopping with this one, it was quite stubborn ( mrs wasn't too happy about me doing it on her table lol)
Filled and primer coat
3 coats of satin black
Lacquer coated three times
Sturdily wrapped and on its way back
Old 27 April 2014, 06:16 AM
craigyp
craigyp's Avatar
fancy doing another one mate?
Old 27 April 2014, 09:18 AM
Rob Day
Rob Day's Avatar
Sure, I think the last chap gave me £30 and he sorted out all the carriers.
Is this ok?
Rob
Old 27 April 2014, 09:23 AM
stonejedi
stonejedi's Avatar
Looks superb,Good work mate.SJ.
Old 23 June 2014, 10:36 PM
petew05sti
petew05sti's Avatar
Looks impressive.if I hadnt of just bought a pink grille badge I would of gone down this route.great work
Old 25 June 2014, 02:47 PM
Kieran-STI
Kieran-STI's Avatar
pm'd
Old 03 July 2014, 11:02 PM
Rob Day
Rob Day's Avatar
Have you got it back Kieran?
Old 17 July 2014, 09:45 PM
Justme103
Justme103's Avatar
My grill is split so I may attempt this & repair it at the same time
