BLOBEYE STI WR BLUE BREAKING(6 speed/asl/twin maps/coilovers/brembos/typhhon k&n)
Old 12 November 2013, 11:53 AM
Default BLOBEYE STI WR BLUE BREAKING(6 speed/asl/twin maps/coilovers/brembos/typhhon k&n)
ok we have another nice 03 plate blobeye sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code
sti semi closed deck £sold
non dccd 6 speed gearbox £sold
r180 larger rear drive shafts excellent working order £180pair
r180 rear hubs very good con good bearings £180pair
6 speed starter motor £45
vf35 turbo £sold
sti larger tmic £sold
sti large under tray good con £sold
oem recirc valve £sold
550cc pink injectors £sold
sti red crinkle inlet £SOLD
lightweight main underdrive pully £sold
full sti car wiring loom uncut or modded minus small engine loom £100
carberry rom mapped sti ecu £SOLD
sti standard headers £sold
full 3inch cat back decatted exhaust £sold
welbro 255 lph fuel pump £sold
k&n typhoon induction kit £SOLD
2 port boost solenoid £20
metal header tank good con no leaks £25
air con pump excellent working order £25
top rad hose good con £10
bottom rad hose good con £5
air con rad good con no leaks or damage £20
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
17inch sti gold alloys £sold
gold brembo front brakes £sold
gold brembo rear brakes excellent working order awesome stopping power with good standard disks and pads loads of life in them 100pcd fitment so fit all year cars great wrx or classic upgrade £250 will not split
Raceland coil over suspension set up £sold
aftermarket front strut brace £SOLD
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
EXTERIOR BODY WORK
sti front bumper £sold
rear bumper £sold
sti front grill with badges good con £40
blobeye alloy bonnet £sold
blobeye sti headlights £sold
blobeye tail lights £sold
blobeye sti wings £sold
sti twisted side skirts £sold
sti rear hi level spoiler £sold
sti boot lid goo£sold
4x doors good con £sold
wing mirrors fully working some paint chips as pictured £45pair
fuel filler door £15
front window good con £45
side mouldings trims £20pair
roof gutter trims £20pair
blue mudflaps £sold
INTERIOR
sti steering wheel £SOLD
boost gauge and pod good working order easy fitment £10
sti seats front and rear £sold
sti door cards complete with switches etc good con £60set
sti blue carpet good con no rips etc great wrx upgrade £60
sti 6 speed red stitch gearknob £25
red stich hand brake lever £20
centre section good con with arm rest £15
sti blue clock set excellent working order £sold
standard double din head unit good working order £20
silver stereo surround good con £25
silver heater surround with vents £15
newage dash top good con £30
boot carpet £25
boot side liners good con £20pair
spare wooden wheel cover £20
Old 13 November 2013, 07:40 AM
Stubarusti
Stubarusti's Avatar
PM sent
Old 13 November 2013, 08:37 AM
Pm replied cheers
All pm's replied
Old 13 November 2013, 02:51 PM
list updated all sold items listed
all pm's replied
Old 18 November 2013, 05:08 PM
list updated all sold items listed and pm's replied
Old 21 November 2013, 10:22 AM
bparkes007
bparkes007's Avatar
I have been looking at the rear bumper on this as it looks to be the same as the hawkeye rear bumper, do you have this one still?
Old 21 November 2013, 10:52 AM
sorry this is the same as the hawkeye one but its sold sorry we have another blue one but it does need painting we could do for £30 pm me if needed
all pm's replied
Old 21 November 2013, 08:10 PM
morandpeter
morandpeter's Avatar
How much for front bumper posted to aberdeen ab51
Old 21 November 2013, 09:27 PM
Sorry the bumper has long sold sorry
Old 23 November 2013, 01:05 PM
list updated all sold items listed and all pm's replied
Old 30 November 2013, 01:46 PM
Old 03 December 2013, 09:45 PM
rudi93
rudi93's Avatar
Matty have you still got the power steering pump mate?
Old 03 December 2013, 10:54 PM
Yes we have that still Rudi pm me if needed
All pm's replied
Old 15 December 2013, 03:45 PM
pm's replied and listed updated all sold items listed
61
11 January 2021 03:08 PM
Quick Reply: BLOBEYE STI WR BLUE BREAKING(6 speed/asl/twin maps/coilovers/brembos/typhhon k&n)
