CLASSIC V5 WRX RA BREAKING (limited seats/oz wheels/4 pots/hi spoiler)
Old 12 November 2013, 02:45 PM
Default CLASSIC V5 WRX RA BREAKING (limited seats/oz wheels/4 pots/hi spoiler)
ok we have a genuine version 5 wrx ra in for breaking at the moment all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
long engine £sold
non dccd 5 speed short ratio gearbox £sold
front drive shafts excellent con £25each
front abs hubs £25each
r160 rear hubs very good con good bearings £180pair
fly wheel no juddering ect £25
5 speed starter motor £30
vf29 roller bearing turbo £SOLD
tmic complete with pipe work mounting brackets £25
under tray good con with water nozzle for cooler spray £30
forge bov £sold
440cc yellow injectors excellent working order £60set
inlet manifold complete with fuel rails £25
standard ra ecu no immoblizer model £60
turbo inlet pipe excellent con un ripped ect £30
standard headers good con £45
3inch turbo back de catted exhaust £sold
standard air box £25
filler cap fit any model £15
2 port boost solenoid £20
lamba sensor genuine part excellent working order £60
coilpack excellent working order £25
genuine ht leads good con £20set
metal header tank good con no leaks £25
top rad hose good con £10
bottom rad hose good con £5
washer bottle with pumps £15
intake snorkel £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
17inch oz p1 style wheels 3sold
Subaru 4 pot front brake set up complete with cailpers and used disks disks and pads cailpers work perfectly 100pcd fitment great wrx or classic upgrade all bolts etc inc £150will not split
rear 1 pot rear brakes good working order complete with cailpers used disks and pads complete £30
ra suspenstion set £sold
gearbox craddle good con £15
alloy front arms complete £70pair
front subframe good con £40
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas pipe with cooler £20
clutch master cylinder £sold
EXTERIOR BODY WORK
facelift front bumper with fog covers doe need paint work as pictured £80
rear bumper £sold
front grill with badges excellent con £sold
alloy bonnet £sold
crystal headlights £sold
crystal side lights £sold
sti rear lights good con great £sold
wings £sold
sti rear hi level spoiler £sold
sti boot lid £sold
4xdoors £sold
INTERIOR
steering wheel in good con with air bag £30
limited edition blue front seats £sold
limited edtion black door cards complete with switches etc good con £60set
carpet good con no rips etc £25
centre section good con with arm rest £15
sti blue clock set excellent working order £70
limited badge and blue stereo/gear surround £sold
limited edtion heater control £25
dash top good con £30
top glove box £sold
spare wooden wheel cover £20
Old 12 November 2013, 04:15 PM
CMSSCOOB
CMSSCOOB's Avatar
PM'd mate
Old 13 November 2013, 08:36 AM
Pm replied Craig cheers
All pm's replied
Old 13 November 2013, 07:35 PM
sthomson1
sthomson1's Avatar
would you sell the fog covers, brackets and clear indicators ?
cost, inc delivery ??
cheers
steve
Old 13 November 2013, 08:11 PM
Laupy
Laupy's Avatar
Hi,
Do you have the timer relay for the IC spray?
Thanks, Paul
Old 13 November 2013, 09:16 PM
Sorry Steve there all going with the bumper only sorry
This model doesn't have water spray kit as standard as far as I'm aware it's had some home made on/off spray kit fitted if some sort sorry
All pm's replied
Old 13 November 2013, 09:48 PM
t16coupe
t16coupe's Avatar
would the suspension on this lower a 1995 wrx or am I thinking of the wrong car as some sti models sit lower
Old 13 November 2013, 10:28 PM
No it wouldn't really the sits sit about 10mm lower so you really wouldn't notice that much difference to be honest
All pm's replied
Old 13 November 2013, 10:49 PM
t16coupe
t16coupe's Avatar
got no other suspension for a classic impreza
Old 13 November 2013, 10:54 PM
I'm afraid not at the moment sorry
Old 14 November 2013, 05:13 AM
zmchone
zmchone's Avatar
Default sti spoiler
What material is the sti high level spoiler made of? Abs plastic like oem or fiberglass?
Old 14 November 2013, 09:49 AM
I believe it's fiver glass fella
All pm's replied
Old 14 November 2013, 09:52 PM
topshot
topshot's Avatar
Rear lights available?
Old 14 November 2013, 10:14 PM
Sorry I'm afraid not sorry
All pm's replied
Old 15 November 2013, 01:16 AM
equinox92
equinox92's Avatar
willing to post the wheel and dash clock to the US?
PM me
Old 15 November 2013, 10:30 AM
I take it you mean steering wheel ?if so yes we can pm me if needed
All pm's replied
Old 17 November 2013, 07:23 PM
BHPvstorque
BHPvstorque's Avatar
Do you have a passenger electric window door console still available ? My rear clip is broken and it vibrates every time I accelerate starting to wind up the Missus ha ha
Old 17 November 2013, 08:01 PM
Yes we will £10 posted for the electric door switch gear pm me if needed
All pm's replied
Old 19 November 2013, 09:48 PM
jersey
jersey's Avatar
how much for the sharkfin spoiler on the roof?
Old 19 November 2013, 10:16 PM
Sorry it's not for sale
All pm's replied
Old 20 November 2013, 12:42 PM
apsrallymodels
apsrallymodels's Avatar
Is this still available Matt
ra suspenstion set up good working order no knocks or leaks etc fully complete £80set
Just gotta confirm something first before confirm fully need
Old 20 November 2013, 04:28 PM
sorry im afraid there not they have gone we do have a sti set now in the red 50mm items if any use
all pm's replied
Old 20 November 2013, 08:11 PM
gf4dad
gf4dad's Avatar
Interested in tail lights, door panels and fog covers
Old 20 November 2013, 08:17 PM
the fog covers go with the bumper only the rear lights aren't for same the door panels I need a address for shipping costs
all pm's replied
Old 21 November 2013, 08:42 AM
apsrallymodels
Do you have picture of them , or even how they sit on the cars itself
Are they also the same price ~??
all pm's replied
Old 21 November 2013, 09:38 AM
they sit slightly lower we have pics later on today but sorry the sti red items are £150 they always fetch more money that the wrx items pm me if needed
all pm's replied
Old 22 November 2013, 02:45 PM
apsrallymodels
Matt, You got them pictures sorted
Ta
Old 22 November 2013, 04:09 PM
il try post some asap we still have them on the car at the moment tho to keep it mobile
all pm's replied
Old 23 November 2013, 01:08 PM
list updated all sold items listed and all pm's replied
Old 30 November 2013, 01:43 PM
all pm's replied
Quick Reply: CLASSIC V5 WRX RA BREAKING (limited seats/oz wheels/4 pots/hi spoiler)
