Newage Parts *LOOK*
Old 23 November 2013, 03:11 PM
badbaz
badbaz's Avatar
Default Newage Parts *LOOK*
****NOTE THAT ONLY PARTS LEFT AND CURRENT PRICING WILL BE IN LATEST POST NEAR END OF THIS THREAD****
Alloy STI blob bonnet, NO scoop, fitted locking aero catches, two keys & bonus McRae Gathering sticker (no undertray), £125
This is collection only as bonnets are impossible to courier safely - hope you understand
Set of 4 blue mudflaps - £SOLD
Blob STI headlights, complete with HIDs & LED sides, detango'd, good condition - £SOLD
STI Impreza 114 hubs x2 rear with ABS rings, sensors & handbrake mounting parts have been completely removed - would suit track car - £75
Impreza STI widetrack rear bumper & arch extensions (bumper has very very minor dent hence price), all brackets, nuts & clips included - £225
The dent can be seen in the pic to the left hand side, it is barely noticeable - the light in this pic highlights it, already removed as are trims, some clips are broken as usual but a couple remain intact
Collection preferred but will pack for your courier collection
STI twisted side skirts, newage with fittings (pair) - £SOLD
2005 Impreza STI front subframe, crash mounts removed & very slightly lightened, powder coated 2013 in black, very nice - £80
(rack & ARB not included)
STI 2.0 coil packs, 4 in perfect order - £SOLD
MY05 Impreza STI Power steering pump with cut down mount if you've relocated your alternator (no pulley included) - £SOLD
Silicone intake pipe no vents, under manifold to turbo, direct replacement for original - £SOLD
Alloy oil catch can with three inlets correct size & one large vent pipe - will chuck in the silicon hoses I have used - £SOLD
STI widetrack shell 55reg with V5C, shell includes windscreen & rear screen, flat boot floor conversion, pitch mount removed, front crash bar supports removed, straight, never crashed, no rust & hpi clear - £SOLD
Make ideal track car build shell
Will sell sections of the shell for the right money, you can come and pick your cut lines
Can deliver local to Lesmahagow area at cost - available now
2005 Blobeye doors taken from a MY05 STI, should fit Bug & Hawk
These doors are all in VGC, perhaps with the odd light ding, will NOT have handles or catches and will be in the following state:
O/S/F - as original with door bars and glass NO winder
N/S/F - minus door bars, modified window rails holding included glass
O/S/R - door is lightened, minus door bars, modified window rails holding glass
N/S/R - door is lightened, minus door bars, modified window rails holding glass
the rears have no door check straps, limo tint on glass and modified rails obviously fix windows in the up position
Suit track car build, could be used on road car with some imagination
£SOLD
Collection only or your courier at your risk
MY05 STI R180 rear diff - £SOLD
MY05 STI 6spd propshaft - £SOLD
MY05 STI 6spd gear linkage fitted with AS Performance bushes giving very precise shift(no gear ****) - £SOLD
MY05 STI front driveshafts(male end), sold in pairs only - £160
MY05 STI rear cradle and T-bar, fitted with Whiteline bushes, minor weight reduction and powder coated black 6 months ago - cradles from this year have no rubber bush mounts to chassis (arms not included) - £110
MY05 STI inlet manifold complete with TGV delete sections and bolts. Included are the standard fuel pipe, FPR & fuel rails. I will include the throttle body and sensors as per the pic if I get my asking price - £SOLD
Blobeye STI grille with pink Subaru badge - good condition £SOLD
Newage STI TMIC bonnet undertray, taken from MY05 STI, perfect order - £SOLD
MY05 STI engine loom £50
MY05 STI throttle body (cable) with TPS & IAC £SOLD
MY05 STI ABS pump £40
MY05 STI Maf £45
MY05 STI Radiator & fans £35
STI standard front disc 114PCD (pair) £35
Newage STI intercooler tank & switch £SOLD
MY05 STI 3 pin alternator £35
DCCD switches newage £20
Power steering reservoir & pipes newage £30
Newage wiper linkage & motor £20
STI widetrack front ARB, droplinks & bushes £20
STI widetrack rear ARB, droplinks & bushes £20
2005 STI plastic coolant header tank, replace that old rusty metal one! £25
2005 STI crank sensor £25
A/C condenser £20
Newage brake master cylinder & servo £20
Newage clutch master cylinder £20
STI 2.0 radiator hoses top & bottom £20
Newage fuel filler flap & cap £15
A/C pump £15
Newage washer bottle £15
Will listen to good offers, postage is extra at cost and paypal fees must be paid in full
Old 23 November 2013, 04:13 PM
Dave Y
Dave Y's Avatar
PM sent
Old 30 November 2013, 10:18 AM
badbaz
badbaz's Avatar
A few items sold, remainder still up for grabs:
PMs answered thanks
Old 30 November 2013, 05:23 PM
Scott's boy
Scott's boy's Avatar
Can I have the mudflaps if still for sale pls
Old 05 December 2013, 08:28 PM
badbaz
badbaz's Avatar
List updated - PMs replied thanks
Old 05 December 2013, 10:58 PM
Big sparks
Big sparks's Avatar
Would you let the brake master and clutch master caps go ? Only need them if poss
Dave
Old 05 December 2013, 11:09 PM
Arch
Arch's Avatar
Baz just had a thought I drove right by your place on Tue going down to Alyn's oops.
Free bump for a genuine seller
Old 06 December 2013, 05:00 PM
l70byb.
l70byb.'s Avatar
pm sent
Old 08 December 2013, 11:12 PM
badbaz
badbaz's Avatar
All sold items updated, PMs replied thanks
Taking offers on remaining items to clear
Old 08 December 2013, 11:20 PM
maydew
maydew's Avatar
Whats lowest on bumper and arches
adamjw2
adamjw2's Avatar
What you doin with the roof scoop if you can get it off without damage
Old 09 December 2013, 12:31 AM
dwootton
dwootton's Avatar
Hi pal long shot but wondering if you still have the cambelt covers front and back
Old 09 December 2013, 09:13 PM
badbaz
badbaz's Avatar
Sold sorry
Old 10 December 2013, 09:25 PM
Wazz777
Wazz777's Avatar
Old 11 December 2013, 10:25 AM
galli RA
galli RA's Avatar
I would have the bonnet if u was not far and wouldn't get damaged if posted:-(
Old 11 December 2013, 01:23 PM
badbaz
badbaz's Avatar
Can't trust them I'm afraid - maybe worth asking on the forum if anyone travels up and down the country
Old 15 December 2013, 09:11 PM
thegeezer
thegeezer's Avatar
Hi, have you got sti TMIC brackets for sale?
Old 15 December 2013, 09:45 PM
badbaz
badbaz's Avatar
No, gone with the TMIC sorry
Old 19 December 2013, 07:00 PM
yabbadoo4
yabbadoo4's Avatar
do you have the standard catted sti downpipe still ?
Old 21 December 2013, 10:06 AM
badbaz
badbaz's Avatar
Diff ends today on ebay and is packed ready to post - grab a bargain while you can
http://www.ebay.co.uk/itm/2613559371...84.m1555.l2649
Collection available from Lesmahagow if you prefer
Old 22 December 2013, 11:25 AM
dazsti72
dazsti72's Avatar
You still got the front subfame?....and would it fit a 2004sti?
Old 22 December 2013, 06:12 PM
badbaz
badbaz's Avatar
Yes, it would if it's a widetrack as steering rack mounts differently apparently
Old 08 January 2014, 05:58 PM
stugsey
stugsey's Avatar
hi badbaz do you have front 02 sensor for downpipe and the aps caik cheers stugsey
Old 16 January 2014, 10:02 PM
Ben Stearn
Ben Stearn's Avatar
Hi Baz, Is the front Bumper still available and what sort of deal could you do on it?
Thanks, Ben
Old 17 January 2014, 10:27 AM
badbaz
badbaz's Avatar
ONLY these parts remain
MY05 STI Maf £45
Newage STI intercooler tank & switch £30
A/C condenser £20
A/C pump £15
Old 17 January 2014, 01:08 PM
galli RA
galli RA's Avatar
Let me know if u ever come southbound would love the bonnet still
Old 26 January 2014, 10:07 PM
badbaz
badbaz's Avatar
List cleaned up, some new prices, last remaining parts
Alloy STI blob bonnet, NO scoop, fitted locking aero catches, two keys & bonus McRae Gathering sticker (no undertray), £PROV SOLD
STI Impreza 114 hubs x2 rear without ABS sensors, rings still present, handbrake mounting parts have been completely removed - would suit track car £75
Impreza STI widetrack rear bumper & arch extensions (bumper has very very minor dent hence price), all brackets, nuts & clips included - £200
2005 Impreza STI front subframe, crash mounts removed & very slightly lightened, powder coated 2013 in black, very nice, nice addition to those winter rebuilds - £80
MY05 STI front driveshafts(male end), sold in pairs only - £150
MY05 STI Maf £45
A/C condenser £20
Newage fuel filler cap £10
A/C pump £15
Will listen to good offers, postage is extra at cost and paypal fees must be paid in full - no excuses
Old 28 January 2014, 02:35 PM
gazzawrx
gazzawrx's Avatar
Will the widetrack rear anti roll bar fit a non widetrack blob?
Old 28 January 2014, 02:58 PM
Oaklee
Oaklee's Avatar
Hi do you have the roof vent?
Old 28 January 2014, 06:43 PM
badbaz
badbaz's Avatar
I'm not sure
Sold
Quick Reply: Newage Parts *LOOK*
