BLOBEYE PPP STI BREAKING (innovite tarmacs/ppp package/6 speed/brembos/sti styling)
Old 26 November 2013, 08:39 PM
Default BLOBEYE PPP STI BREAKING (innovite tarmacs/ppp package/6 speed/brembos/sti styling)
ok we have another nice 03 plate blobeye sti in 18l black with the gold fleck for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 18L
sti semi closed deck £sold
non dccd 6 speed gearbox £sold
r180 larger rear drive shafts excellent working order £180pair
r180 rear hubs £sold
6 speed starter motor £45
vf35 turbo charger£sold
sti larger tmic £sold
sti large under tray good con £sold
bailey dv26 dump valve £sold
550cc pink injectors excellent working order £sold
sti red crinkle inlet tgv delete inlet £sold
full sti car wiring loom uncut or modded minus small engine loom £100
prodrive ppp mapped 305bhp sti ecu with key set and barrel/door/boot locks with sendor unit £150complete
sti standard headers £sold
ppp sports cat down pipe good con great upgrade and still legal for mot time wrx models also £150
prodrive ppp cat back exhaust £sold
prodrive ppp welbro 255 lph fuel pump excellent working order great upgrade part £30 or £40 with sendor unit complete
standard air box £25
k&n performance panel filter very good con fully reusable life time warranty £25
2 port boost solenoid £20
metal header tank good con no leaks £25
air con pump excellent working order £25
top rad hose good con £10
bottom rad hose good con £5
air con rad good con no leaks or damage £20
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
17inch innovate tarmac gold alloys with sport budget tyres all with excellent tread roughly 5mm on all tyres wheels are 17x 7j et 45 muilti stud pattern so will fit 100 pcd and 114pcd also clear large brembo brakes also all very good con no curbing on any wheel complete with tuner slim will nut and tool £300
gold brembo rear brakes excellent working order awesome stopping power with good used drilled disks and pads 100pcd fitment so fit all year cars great wrx or classic upgrade £250 will not split
sti suspension set £sold
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
sti 100pcd space save clear large brembos £25
EXTERIOR BODY WORK
sti front bumper £sold
rear bumper in good con no and straight no damage and good paint £80
sti front grill with badges good con £60
blobeye alloy bonnet £sold
blobeye sti headlights very good con nice and clean and unmessed with £250will not split
blobeye tail lights good con great hawkeye and bugeye upgrade £100pair
blobeye sti wings £sold
blobeye inner splash guards good con £60pair
sti twisted side skirts £sold
sti rear hi level spoiler genuine item in good con no damage all genuine item and paint work in in very good order ready to fit with full brake lights and fixing £300
sti boot lid good con nice and straight with good paint work complete with badges NO BOOT LOCK INC £60
4x doors good con no damage and good paint £sold
wing mirrors good con fully working £45pair
fuel filler door £15
front window good con £45
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
sti steering wheel £sold
sti seats £sold
sti door cards £sold
sti blue carpet good con no rips etc great wrx upgrade £60
sti 6 speed red stitch gearknob £25
red stich hand brake lever £20
centre section good con with arm rest £15
sti blue clock set £sold
oem double din stereo good working order £20
silver stereo surround good con £25
silver heater surround with vents £15
newage dash top good con £30
boot carpet very good con £25
boot side liners very good con £20pair
spare wooden wheel cover £20
Old 27 November 2013, 06:04 PM
ohyainnit
ohyainnit's Avatar
Pm sent
Old 27 November 2013, 06:05 PM
pics now added and all pm's replied
Old 27 November 2013, 07:18 PM
LeeRoyV
LeeRoyV's Avatar
How much delivered for the inlet with tgv deletes??? Perhaps drop me a pm
Old 27 November 2013, 08:30 PM
Pm sent and all pm's replied
Old 30 November 2013, 01:51 PM
list updated all sold listed and pm's replied
Old 30 November 2013, 06:30 PM
K3ogh_sti
K3ogh_sti's Avatar
i need a washer bottle cap, any lying around dude?
chris
Old 30 November 2013, 06:49 PM
Hi chris to be honest for the cost of new your best of buying new as we sell them with the washer bottles fella
All pm's replied
Old 02 December 2013, 03:26 PM
ohyainnit
ohyainnit's Avatar
Seats and door cards turned up this morning nice one Matty already fitted them lol looks much better
Old 02 December 2013, 04:16 PM
awesome that's good news glad to hear hope you enjoy thank you again
all pm's replied
Old 11 December 2013, 10:42 PM
SirFozzalot
SirFozzalot's Avatar
I'm interested in the rear bumper.
Does it come with all the mounting brackets etc? (including the main two central brackets that go into the rear of the car?)
How much delivered to Essex?
Old 11 December 2013, 10:48 PM
Sorry if have to check if the bumper is still available as it was meant to been collected il check in the morning for you
All pm's replied
Old 15 December 2013, 03:58 PM
pm's replied list updated all sold items listed
Old 22 February 2014, 12:04 AM
scooby doo sti
scooby doo sti's Avatar
Is the rear bumper and boot still available off this car?
Old 22 February 2014, 08:31 AM
Boot lid yes bumper I'm afraid has long sold
Old 08 March 2014, 11:41 AM
Smiffy852
Smiffy852's Avatar
Hi, any chance you have a driver side front wing?
Old 08 March 2014, 04:25 PM
Sorry in afraid they have log sold sorry
Old 21 March 2014, 05:14 PM
jr758774c
jr758774c's Avatar
I'll take the boot lid please. Send me an invoice to my paypal - jr758774c@hotmail.co.uk
Mark
Old 21 March 2014, 10:08 PM
Sorry it's already sold sorry
Old 24 April 2014, 11:59 AM
zenith
zenith's Avatar
Spoiler still available?
Old 24 April 2014, 02:26 PM
Sorry it's long sold I'm afraid we have one in silver if that helps tho
Old 27 April 2014, 02:35 PM
mctwistuk
mctwistuk's Avatar
Don't suppose you still have the wheels Matty?
Old 30 April 2014, 10:08 AM
Daphne01
Daphne01's Avatar
I realise that this was a lifetime ago but any chance you have the bonnet. Don't need scoop.
Old 30 April 2014, 03:56 PM
mct sorry wheels have long sold im afraid
daphne sorry im afraid it was also sold a long time ago we have no others in this colour im afraid sorry
Old 30 April 2014, 11:48 PM
scot1888
scot1888's Avatar
I don't suppose you still have the sports cat downpipe do you?
If so could you pm me a price delivered to Cumbria please.
Old 01 May 2014, 08:23 AM
Sorry no we haven't it's a very old advert all parts have sold off this car I'm afraid
61
11 January 2021 03:08 PM
Quick Reply: BLOBEYE PPP STI BREAKING (innovite tarmacs/ppp package/6 speed/brembos/sti styling)
