Just need confirming about new age TMIC
Old 06 December 2013, 11:03 AM
SwissTony
SwissTony's Avatar
Default Just need confirming about new age TMIC
Looking to replace the standard TMIC on my classic. Was going to go down the road of a V4/5 Sti TMIC but reading up it seems the volume between the two is hardly nothing so maybe not worth it aside from the ease of swapping like for like.
As there is no need for me to go FMIC as my power is pretty standard, I was looking at a new age TMIC . Seen a great link on here on how to do it. It seems one hell of a job but I do like a good challenge
Question is : just how much work is there involved and does anybody have a newage Sti top mount with a classic fitting kit ? I am sure I can source the top mount but just wondering if anyone has the bits to make the job easier ?
Old 06 December 2013, 11:09 AM
MattyB1983
MattyB1983's Avatar
What about a newage wrx top mount. Cheap as chips to buy, bigger than standard classic top mount and pretty much bolt straight on.
Old 06 December 2013, 11:11 AM
banny sti
banny sti's Avatar
Depends on the year of the car but the v5/6 wont need the dv cutting out
http://www.carldavey.co.uk/article.php?id=3
Old 06 December 2013, 11:28 AM
SwissTony
SwissTony's Avatar
Thanks guys for the replies. Year of my car is MY00. Looking at some of the guides I think I may have found another problem which may not allow me to go newage
Have an Sti strut brace to fit and it seems the clearance could be a tad tight to allow fitting ..damn
Matty, when you mention WRX TMIC , you say they are 'pretty much bolt on'
I assume the fixings are different then from the newage Sti ones ?
Old 06 December 2013, 11:38 AM
banny sti
banny sti's Avatar
WRX tmic is smaller in size so should fit no probs
MattyB1983
MattyB1983's Avatar
Slightly smaller than the sti one I believe and only require minor adjustment to fit a late classic. You can also still retain the classic sti strut brace when using a newage wrx top mount.
Old 06 December 2013, 12:17 PM
adz556
adz556's Avatar
I have a wrx tmic you can have for next to nothing if your interested. Pm me if you want
Old 06 December 2013, 12:26 PM
Tidgy
Tidgy's Avatar
whats model is it swis?
Old 06 December 2013, 12:35 PM
SwissTony
SwissTony's Avatar
Perfect that sounds like the answer I need. Increase the volume for future extra power and at the same time retain some of the kit I have to fit without too much fettling
Thanks once again
Old 06 December 2013, 12:36 PM
SwissTony
SwissTony's Avatar
did you mean New Age top mount ?
SwissTony
SwissTony's Avatar
Model of my car ?
My00 classic
Old 06 December 2013, 12:38 PM
Tidgy
Tidgy's Avatar
sti, uk?
Old 06 December 2013, 12:40 PM
SwissTony
SwissTony's Avatar
sti, uk?
sorry UK
Old 06 December 2013, 12:42 PM
Tidgy
Tidgy's Avatar
ah k, still on the td04?
Old 06 December 2013, 12:48 PM
SwissTony
SwissTony's Avatar
Yes and I know what your next question will be :loll:
Why bother !!
Well I know that standard power means the standard intercooler is fine but I was looking to improve the capacity for future gains/power. Kind of being prepared which as a good boy scout is always done
Old 06 December 2013, 12:50 PM
Tidgy
Tidgy's Avatar
no was more a case of td04 is the only situation sto stick with top mount, anythign bigger fm is way to go
if its for future proofing then i wouldn;t bother doing anythign and save your money for a fm
Old 06 December 2013, 01:01 PM
SwissTony
SwissTony's Avatar
Actually if you read on here you will see quite a few discussions about what level of power you need to go to warrant a FMIC over the top mount. The agreement (well as much as anyone on here can agree ) is anything over 350 needs a FMIC.
And as I am not chasing big power now or in the future TMIC is enough for me
Old 06 December 2013, 01:15 PM
Tidgy
Tidgy's Avatar
not sure agreed by who, usual scoobynet massive i bet without any actual testing lol. scoobyclinic did back to back testing on standard, uprated top mounts and a front mount and it showed 20bhp gain at 300bhp, Harvey RIP did alot of testing around it, although mroe aimed at lag and the lack of it being caused by front mounts as well as inlet temp monitoring.
Something to bear in mind is its not just about power figures, its about heat and build up. Its very much a case of what you dont loose rather than what you gauin. At the end of the day its totaly your choice but having bin there and done that i woudl go front mount as soon as i switched out the td04. Front mounts arn't huge amounts more money that a top mount
Old 06 December 2013, 01:18 PM
adz556
adz556's Avatar
Newage wrx tmic
Old 06 December 2013, 01:34 PM
SwissTony
SwissTony's Avatar
October 2012 I see you were in that discussion I mentioned
I see your point mate, on my old scoob I had front mount and it was running 300bhp so it at that level where it was needed. But I am not at that level on my current scoob so just getting ready ..
Old 06 December 2013, 01:38 PM
Tidgy
Tidgy's Avatar
haha yeah, i can never figure out why it becomes such a debate, the back to back's prove it, yet people seem to stillw ant to argue cos of what they think, figure that otu if you can hahahaah
Old 06 December 2013, 05:04 PM
The Trooper 1815
18 June 1815 - Waterloo
The Trooper 1815's Avatar
Tony, here's my old V5 STi with a WRX TMIC. Only a little fettling required to get it to fit
Old 06 December 2013, 08:20 PM
SwissTony
SwissTony's Avatar
Looking good there, going for the same look as what I want (aside from the tarty red hoses )
Might have to pick your brains re the fitting
Old 06 December 2013, 08:40 PM
Oggy249
Oggy249's Avatar
I fit one on my my99 was easy just alter the bracket a bit and make sure you use the classic Y pipe
Old 06 December 2013, 09:01 PM
SwissTony
SwissTony's Avatar
got you
Old 06 December 2013, 09:36 PM
Steve Whitehorn
Steve Whitehorn's Avatar
As you guys know. In addition all that testing Harvey did - The quality of the Mapping and the up pipe also have big effects on the amount of lag. Apparently better throttle response on a top mount though....what am I doing! .....I will shut up - and leave the can of worms firmly closed .
Just stick the top mount on Swiss and go for it lol
Old 06 December 2013, 09:58 PM
swaynie
swaynie's Avatar
Just to add as im looking for a V5-6 car to buy and upgrade the TMIC. Instead of doing the STI change I can use a Newage WRX one as said above with less mods to be done to get it to fit. The one in my link would be perfect?
http://www.ebay.co.uk/itm/SUBARU-IMP...item1c381bd7c8
Old 06 December 2013, 11:42 PM
The Rig
The Rig's Avatar
i opted for the 2003 TMIC on my 95 wrx as the cost involved with a TMIC was alot cheaper than the front mount.
From
To
with the 2003 undertray adapted to suit the classic bonnet/mounting holes
and of course,the scoop to suit LOL
This is the bit (pic borrowed from the net) i had to "manipulate" to get the TMIC to sit properly and not hit/rub/vibrate when engine moved etc
As said,there is alot involved to get it to fit,where the dumpvalve goes on the TMIC is welded,but you can get cover plates instead,which is easier/cheaper.
The throttle body has also been shortened,where the outlet meets the TMIC to allow fitment as it would be very very tight against the bulkhead
If thats not put you off,go for it LOL
Old 06 December 2013, 11:52 PM
MattyB1983
MattyB1983's Avatar
Its much easier to fit a newage wrx top mount on a phase 2 engine like the ops.
No cutting or welding required on the cooler.
Old 07 December 2013, 12:15 AM
The Rig
The Rig's Avatar
yeah, the cooler is easier to fit as in no welding to it, but, you still need to "amend" the bit i mentioned, otherwise it knocks like **** on hard acceleration and if you dont trim the throttle body, it hits the back of the bulk head and its real tight LOL but some guys dont do what i did and are happy, i just hated hearing the thump thump thump all the time !
Quick Reply: Just need confirming about new age TMIC
