Full Cars Breaking For Spares This forum contains details of cars being broken for spares by our members.
2003 Subaru Impreza WRX STi Type UK - 406bhp/385lbft - BREAKING
Old 13 January 2014, 10:56 AM
ScoobyDoo69
ScoobyDoo69's Avatar
Default 2003 Subaru Impreza WRX STi Type UK - 406bhp/385lbft - BREAKING
CAR IS NO LONGER BEING BROKEN AS I HAVE RECEIVED A DEPOSIT FOR THE WHOLE CAR - SEPARATE THREADS WILL BE CREATED FOR THE PARTS AVAILABLE - THANKS FOR LOOKING!
Hi all,
I am regretably breaking my car. I have not come to this decision lightly, especially having owned this car for nearly 6 years. However, needs must!
I will begin breaking the car as of 1st February 2014 and I will be doing it over the course of time stripping things like interior and performance mods first. Body parts will be the last thing I take off, so please bare this in mind.
Collection of all and any parts are available from the South Birmingham area.
All prices advertised are without postage - and the postage price will be based on what I am quoted based on size and weight.
Payments can be made to me via PayPal to kostandinokustas@googlemail.com - all fees to be paid by you.
Bank transfer and cash in hand are both an also an option.
If you wish to collect a part then a minimum of 10% needs to be paid to myself to hold the part for you. Obviously you can pay the full amount up front if you so wish.
No parts are reserved for anyone unless a deposit has been received.
This deposit will be non-refundable unless you deem the part to not be as described. I will refund any and all deposits if the car sells as a whole.
If you are interested in the car as a whole then it is available at the right price. Certain modifications can be removed to come to a more agreeable price.
Basic details for car as a whole
53k miles - tax until November 2014 - MOT until July 2014
Regular servicing of minimum of oil change every 6 months - Fuchs or Motul only used
Cambelt changed at API along with their modified oil pump
Plenty of other service history done either by API or myself
406bhp/385lbft made with 20% Meth mixed with V-Power on RCM dyno
Mapped by Duncan @ RaceDynamix
Below are some recent pictures, I will add more pictures of parts etc as and when they come off the car. All prices are negotiable, but silly offers will be ignored.
EDIT
Couple of pictures I found on my phone to help show the steering wheel, ATi steering pod, seats, and general condition of the interior.
Engine shot is a slightly old one as this was before the Mishimoto turbo inlet pipe was fitted. More to come tonight/tomorrow.
EDIT 2
Some interior pictures taken just now on my phone. This should help see the steering wheel gauge pod (picture shows it with only 1 gauge pod, I have the other one in a box at home as I didn't need to use it) the centre pod and gauges, the headunit, the interior seats, mats, carpets, dashboard etc.
As you can see, all in very good condition!
Edit 3:
Dyno graph at RCM before and after porting of VF43:
Edit 4 19/01/2014:
Some new pics taken today after a decent wash.
Showing damage to front lip (ignore BBS wheels... they are not for sale):
Engine & Performance
STi long engine - plug above cylinder 3 is sealed off hence price - will take offers £1,000.00
Complete VF43 Turbo - Ported by API - Forge Motorsport 1bar actuator - Made 406bhp on RCM dyno £500.00
VF43 Turbo - Ported by API - standard actuator £400.00
Forge Motorsport VF43 1bar actuator £100.00
Mishimoto turbo inlet pipe £125.00
Samco inlet elbow £60.00
RCM Induction kit £100.00 DEPOSIT RECEIVED - Lee Elliot
STi intercooler with motorbike fan £175.00
Harvey Smith ported headers & stainless up pipe - wrapped with exhaust wrap £200.00 DEPOSIT RECEIVED - sovietspybob
Haywood & Scott true 3" long downpipe - wrapped with exhaust wrap £175.00 DEPOSIT RECEIVED - Luther
Blitz Nur Spec R cat back exhaust system - modified to true 3" system £350.00
Cobra SB04 true 3" track day exhaust system cat back £250.00 DEPOSIT RECEIVED - Luther
VF34 P18 exhaust housing brand new £125.00
Spec C anti-surge fuel assembly £350.00
Walbro Fuel Pump (less than 5k use) £50.00
RCM Fuel Pressure regulator with braided hosing £140.00
STi 550 injectors £80.00
RCM baffled oil sump (less than 5k use) £400.00
Prova Air/Oil Seperator with hosing £150.00
Mocal oil cooler kit including thermostatic plate & hosing £125.00 DEPOSIT RECEIVED - Shmerman
Standard oil sump £100.00
STi inlet manifold £100.00
API inlet manifold spacers £50.00
API lightweight pulleys £80.00
Newage radiator £40.00 DEPOSIT RECEIVED - Frankurry
Newage radiator hoses £20.00
Air con radiator £20.00
Air con pump £25.00
Alternator £25.00
Powersteering pump £25.00
Engine Wiring loom £50.00
Rest of loom £80.00
MAF £40.00
Drivetrain
STi 6 speed gearbox - rebuilt by API with the carbon synchros and replacement 4th gear £1,700.00
Front driveshafts £80.00
Front hubs £50.00
R180 rear driveshafts £150.00
R180 rear hubs £150.00
Gearbox speedo sensor £35.00 DEPOSIT RECEIVED - Dean Mahon
Chassis
Front Brembo Brakes - EBC drilled/grooved disks and Bluestuff NDX pads £400.00 DEPOSIT RECEIVED - Matthew Clift
Rear Brembo Brakes - standard disks and Bluestuff NDX pads £250.00
BC Coilovers with rear extended adjusters £400.00 DEPOSIT RECEIVED - r33gts2009
Whiteline 24mm rear ARB £100.00 DEPOSIT RECEIVED - rosscooper
Whiteline rear ARB links £50.00
Whiteline front adjustable ARB links £50.00 - DEPOSIT RECEIVED - r33gts2009
Whiteline roll correction kit - front ball joints & track rod ends £100.00 DEPOSIT RECEIVED - r33gts2009
Newage front strut brace £30.00
Newage rear strut brace £45.00
Newage STi steering rack £100.00
STi front alloy arms with castor mod performed £100.00
Interior
STi interior - very good condition seats & door cards £500.00
Alpine double din touch screen DVD headunit £40.00 DEPOSIT RECEIVED - Dan Hardwick
Defi 52mm Gauges - Oil temperature, oil pressure, boost pressure, fuel pressure (slight crack in face) - all working 100% with sensors £550.00
ATI centre dash gauge pod - clips broken at the front £50.00 DEPOSIT RECEIVED - palma0778
ATI steering cowling gauge pod £75.00 DEPOSIT RECEIVED - Stuart Page
Cobra Suzuka bucket seats with original Cobra mounts £400.00
Dash kit £50.00
2003 STi ECU, key and locks £200.00
STi 6 speed gearknob £30.00
Scangauge £75.00
WR1 STi DCCD dash cluster - showing 53k miles £50.00
STi steering wheel £50.00 - DEPOSIT RECEIVED - Michael White
Dashboard top - very good condition £50.00
Carpets - very good condition £50.00
STi Type UK mat sets (original Subaru items) x 2 £40 each DEPOSIT RECEIVED FOR ONE SET - Frankurry
Waterspray kit - including bottle, piping, switches etc. £60.00
Drivers side window regulator £10.00
Fire extinguisher & mount £50.00 DEPOSIT RECEIVED - Frankurry
Exterior
Sti V8 Wheels - Vredstein Ultrac Sessanta tyres 225/45/17 - 2 just replaced less that 1k miles ago - comes with 2 spares with 2.5mm tread £300.00 DEPOSIT RECEIVED - Arch
02C STi genuine boot spoiler £250.00
02C Newage Bootlid - SUBARU lettering removed £100.00
02C Blobeye front wings £150.00 - DEPOSIT RECEIVED - Infected By STI
02C newage doors, complete with glass and window regulators - £45 each
02C STi complete front bumper with Zunsport grill, winglets & HTAutos front lip (small piece missing on driver side) £350.00
Zunsport grill separate - Would like to keep this on the bumper for now so I don't end up with holes left in a bumper I'm trying to sell. Will sell seperate if I find a buyer for the bumper £40.00
02C Blobeye STi rear bumper £100.00
02C Blobeye STi mirrors £50.00
02C Blobeye Sti twisted sideskirts £100.00
02C Newage Shell £600.00
Blobeye STi intercooler undertray £60.00
02C STi Blobeye bonnet and scoop £250.00
Blobeye STi front headlights £250.00
Blobeye Sti rear lights £125.00
02C Blobeye STi fog light covers £50.00
02C Blobeye fog light surrounds £50.00
ScoobyWorld Mudflaps £25.00 DEPOSIT RECEIVED - Frankurry
Blobeye STi debadged Sti front grille £50.00 DEPOSIT RECEIVED - Oli_P
It's likely that I've made some mistakes in the advert and/or missed things out which are available. List is copied from my spreadsheet so apologies for the formatting.
I will do my best to answer any and all questions/PMs as soon as possible.
Thanks for looking.
Kosta
Old 13 January 2014, 11:15 AM
chet123
chet123's Avatar
right, lets kicked this off. I'll take the RCM induction bro - make sure it aint filthy lol
Old 13 January 2014, 11:24 AM
Scoobydoo Ste
Scoobydoo Ste's Avatar
PM'd re Zunsport Grill
Old 13 January 2014, 11:27 AM
oli_p
oli_p's Avatar
id be interested in the front grill, also what most is the alpine headunit, im assuming the price is an error or just an old model??
Old 13 January 2014, 12:54 PM
Scooby_Lee101
Scooby_Lee101's Avatar
RCM induction kit please
Potentially headers and up pipe aswell
Old 13 January 2014, 02:41 PM
Arch
Arch's Avatar
PM sent on 22B ref wheels and tyres
Old 13 January 2014, 03:11 PM
r33gts2009
r33gts2009's Avatar
Zunsport lower grill ,whiteline front adjustable drop links & whiteline correction kit & seats depends on condition pls
Old 13 January 2014, 07:37 PM
ScoobyDoo69
Thanks for all the interest so far guys, I'll be doing my best to ensure that you all get a reply.
There has been a lot of demand for the Zunsport grille. I would like to say that I want to keep it on the bumper for now, else I end up with a front bumper with holes in it to sell! Hope you all understand.
If the car does get sold as a whole (had a few queries so far) then all deposits WILL be returned.
Hi, everyone is after the front grille. I have to say that at the moment I'd like to leave it on the bumper as otherwise I'd have to sell a front bumper with holes in it. Hope you understand.
The Alpine unit is an old one yes. I think it is the Alpine IVA W200 - I will double check for you.
Bit of demand on the RCM kit so as in the original post thread, first deposit holds it. Put you down for the rest.
As above with the Zunsport grille. Want to keep it on the bumper for now. Apologies.
Seats are in good condition - no rips or anything. I'll be sure to post some pictures for you.
Old 13 January 2014, 07:42 PM
oli_p
oli_p's Avatar
I could part ex a grill with you?? Have a WRX one, with an I badge on it,if needed you could keep the STi badge of yours aswell to stick on mine and sell that with the bumper??
Old 13 January 2014, 07:45 PM
ScoobyDoo69
Ah my apologies! I thought you meant the Zunsport lower front grille. Yes that is available without the front bumper!
Old 13 January 2014, 07:47 PM
oli_p
oli_p's Avatar
ok I shall leave a deposit now then if that ok??
Old 13 January 2014, 07:48 PM
ScoobyDoo69
Yup feel free! Deposit or full amount, so long as you pay the paypal fees
Old 13 January 2014, 07:50 PM
oli_p
oli_p's Avatar
Ill leave a deposit for now, incase the whole car sells, plus id need postage adding on top aswell, although if you want to sell anyway as said I could always part ex it with mine, so will still have something in place if car sells whole?
Old 13 January 2014, 07:55 PM
palma0778
palma0778's Avatar
Old 13 January 2014, 08:00 PM
oli_p
oli_p's Avatar
deposit left for the grill
Old 13 January 2014, 08:02 PM
ScoobyDoo69
Ok just send over a deposit. If the car sells as a whole I will keep you in mind to see if the potential owner would rather my grille or yours. Thanks
Originally Posted by palma0778
Ill take ATI centre dash gauge pod+postage.Let me know about pay some deposit
Hi palma, not sure what postage will be until I take it off the car. But Paypal details are in the first post. 10% deposit holds it for you!
Old 13 January 2014, 08:03 PM
ScoobyDoo69
Received!
Old 13 January 2014, 08:05 PM
palma0778
palma0778's Avatar
Alright mate ill pay 10£ now and rest +postage when u ready.
ScoobyDoo69
Deposit bro! I need to be fair to everyone lol!
Old 13 January 2014, 08:08 PM
galli RA
galli RA's Avatar
would u take 200 for bonnet and scoop
Old 13 January 2014, 08:12 PM
palma0778
palma0778's Avatar
Deposit paid for Ati centre pod mate.Let me know when u ready.
Old 13 January 2014, 08:23 PM
stugsey
stugsey's Avatar
Hi m8 is it a Harvey smith uppipe if so how much just for uppipe cheers
Old 13 January 2014, 08:27 PM
ScoobyDoo69
Sorry that's too low.
Received. Thanks.
Hi, sorry but I have just received a deposit for the headers and up pipe. So it would no longer be available. I will let you know if it becomes available again.
Thanks.
Old 13 January 2014, 08:34 PM
stugsey
stugsey's Avatar
Ok do u have the sensor bolted into headers then and how much. If the person do not buy the header/ uppipe I will take them for cash ok
Old 13 January 2014, 08:41 PM
ScoobyDoo69
I will be selling the headers with the sensor as it was a brand new sensor.
I do however have a perfectly working sensor which you can have for £20 and I can send out immediately.
Old 13 January 2014, 09:00 PM
galli RA
galli RA's Avatar
if the bonnet is in top cond ill take it
Old 13 January 2014, 09:03 PM
stugsey
stugsey's Avatar
Ok m8 but it has to be a header 1 ok. Also how much for the front lip
Old 13 January 2014, 09:29 PM
ScoobyDoo69
Bonnet has no dents, just usual stone chips.
It is definitely the header one. Front lip has a bit missing on the drivers side, but I'd like to try and get rid with the front bumper if possible first.
Thanks.
Old 13 January 2014, 10:17 PM
ScoobyDoo69
Right, signing off for the night. Thank you to all those who have messaged and sent deposits.
Regards
Kosta
Old 14 January 2014, 09:36 AM
Scoobygraeme
Scoobygraeme's Avatar
Sent a pm.
Quick Reply: 2003 Subaru Impreza WRX STi Type UK - 406bhp/385lbft - BREAKING
