thicko alert.....!!
Old 01 September 2006, 11:03 AM
island991
island991's Avatar
Default thicko alert.....!!
...im probably being really thick. but how do i remove the trim below the steering wheel on a MY00?? trying to get at the back of the fog light switches!! can only see clip on end, but doesnt seem to loosen much
Old 01 September 2006, 11:06 AM
jd5217
jd5217's Avatar
there are a couple of screws too.
island991
island991's Avatar
hmmmm.....where?!!!
Old 01 September 2006, 11:07 AM
jd5217
jd5217's Avatar
yhpm
Old 01 September 2006, 11:08 AM
island991
island991's Avatar
Im thinking of doing these gauges myself. Has anyone in guernsey done this on a classic themselves?
Old 01 September 2006, 11:09 AM
jd5217
jd5217's Avatar
should be similar to a newage.
which gauges?
Old 01 September 2006, 11:16 AM
island991
island991's Avatar
boost and oil temp. I know its fairly straight forward (for people other than me!!). Boost from blanked off nipple ready for the job. and oil temp from top cyl3. But its avoiding hot bits with the wiring and general electrical stuff im not keen on.
Old 01 September 2006, 11:20 AM
jd5217
jd5217's Avatar
had a mate who is an electrical engineer sort the wiring on mine.
Old 01 September 2006, 11:23 AM
island991
island991's Avatar
Hmm....not sure i know any electrical engineers!!!
also i can find anything about removing trim in those pages.....anyone else able to help??!!!
Old 01 September 2006, 11:28 AM
jd5217
jd5217's Avatar
on mine there are 2 screws right at the bottom of the panel pointing up.
Old 01 September 2006, 11:32 AM
movi-star
movi-star's Avatar
There are 2 screws, one is where the bonnet release handle is, the second one is the other side low down. The top part is held down by clips which you can just pull off.
Old 01 September 2006, 11:34 AM
island991
island991's Avatar
hmm....some chance of me fitting gauges when i cant even get the first bit of trim off!!!
Old 01 September 2006, 11:35 AM
jd5217
jd5217's Avatar
could be entertaining
Old 01 September 2006, 11:42 AM
jjones
jjones's Avatar
stick then onto the dashboard with gripfill.
Old 01 September 2006, 11:44 AM
jd5217
jd5217's Avatar
and connect them to?
Old 01 September 2006, 11:50 AM
jjones
jjones's Avatar
open the window a little and feed the tube for the boost pipe out of the window and in through the edge of the bonnet. try not to get it crimped else the boost gauge will give inaccurate results.
for illumination you can gripfill a maglight in front of gauges, at the correct angle.
Old 01 September 2006, 11:52 AM
island991
island991's Avatar
shut up you lot!!!
managed it now!! just was investigating really! not actually attemping gauges today. Im intending to have a switch wired in so that i can turn off light feed to gauges if i want. (esp as im gonna have an a-piller set up, can imagine that on a simple motorway drive in the dark i might want them out of my vision for a while)
Old 01 September 2006, 11:54 AM
island991
island991's Avatar
how about feeding all tubes/wires out of bonnet scoop and gaffertaping them to the bonnet, then drilling a hole in windscreen to feed them through??
Old 01 September 2006, 11:56 AM
jd5217
jd5217's Avatar
remember to use a blunt drill bit though.
Old 01 September 2006, 11:57 AM
jjones
jjones's Avatar
now we're talking
Old 01 September 2006, 11:58 AM
jd5217
jd5217's Avatar
shut up you lot!!!
dependant on the gauges, the wiring for the lighting is built in and cannot be turned off.
Old 01 September 2006, 12:00 PM
island991
island991's Avatar
bugger
Old 01 September 2006, 12:01 PM
jd5217
jd5217's Avatar
what gauges you got.
Old 01 September 2006, 12:06 PM
island991
island991's Avatar
autogauge stealth 2006 with the opening sweep calibration thing.
Old 01 September 2006, 12:09 PM
jd5217
jd5217's Avatar
they illuminate with power.
i have the stealth 2 gauges.
Old 01 September 2006, 12:14 PM
island991
island991's Avatar
hey ho. anyway just have to get them fitted then!!
Old 01 September 2006, 12:18 PM
jd5217
jd5217's Avatar
Lucas House could probably fit them.
Go & speak to Nick.
Old 01 September 2006, 12:24 PM
island991
island991's Avatar
is that down by the chippy?
Old 01 September 2006, 12:27 PM
jd5217
jd5217's Avatar
yep, pitronnerie road.
Old 01 September 2006, 12:32 PM
island991
island991's Avatar
are they good?
Quick Reply: thicko alert.....!!
