Originally Posted by harvey
(Post 9286983)
Sorry. Never come across that trans. code. Are you sure it is right?
as far as i know yes :thumb: altho could be wrong :wonder: i've had it passed on from a friend so it is possible .. |
hi david anotyher gear box problem my transmission code is ty752vb3fa whioch gear box will fit my diff, please help kind regards.
Originally Posted by APIDavid
(Post 8859936)
Ref post 7. You cannot put a VN series box in an import WRX without changing the rear diff, they are the wrong ratio. So to clarify; IN A UK CAR; any VN box will go in place of any other VN box.
BUT if this is a VN box in an import car, you will need to check that the rear diff is the matching 3.545 UK ratio. If you put in a VN box where a VB box has come from, you will go 30 miles with a big vibration, then there will be a bang, the vibration will stop as the centre diff has just broken, and you will have a nice, silent, vibration free, 2wd transmission........ If you haven't changed to the matching rear diff. David APi |
hello every one,need a bit of info and this seems to be the thread to ask. ive got a 1993 legacy single turbo 4x4 with a gear box code TY752VN1BA. cant find this code on any charts i can find on google. so wat diff is this running and is there a box to match up. cheers gaz.
Hi. Sorry to hijack some1 elses post but I'm new to this forum stuff n havnt got a clue how to use it. Where is the best place to get a gearbox rebuilt in Essex?
